GPIO中断输入检测,如何配置为双边沿触发 GR551x
手环啊
2020-10-09 16:39
文档里面没有介绍,有劳技术小哥解答下
walt
你好,gr5515 io支持下降沿,上升沿,高电平,低电平触发中断,暂不支持双沿触发
如果使用双边沿触发,可以在中断发生时更改io中断触发设置以实现功能
手环啊
2020-10-13 11:43
是这样吗?触发中断后,重新配置,但是我这样配置了之后,就只能触发一次中断,之后不管上升沿还是下降沿都进不去了,是哪里没有弄对吗?
void high_gpio(void);
void low_gpio(void);
void hal_gpio_exti_callback(gpio_regs_t* GPIOx, uint16_t GPIO_Pin)
gpio_pin_state_t pin_level;
if(GPIO_Pin & GPIO_KEY0)
pin_level = hal_gpio_read_pin(GPIO_KEY_PORT, GPIO_KEY0);
tim_delay_ms(10);
if(pin_level == GPIO_PIN_RESET)
printf("\r\nKEY0 down pressed.\r\n");
high_gpio();
else
printf("\r\nKEY0 up pressed.\r\n");
low_gpio();
void low_gpio(void)
gpio_init_t gpio_config = GPIO_DEFAULT_CONFIG;
gpio_config.mode = GPIO_MODE_IT_FALLING;
gpio_config.pin = GPIO_KEY0;
gpio_config.pull = GPIO_PULLUP;
hal_gpio_init(GPIO_KEY_PORT, &gpio_config);
/* Enable interrupt */
hal_nvic_clear_pending_irq(GPIO_GET_IRQNUM(GPIO_KEY_PORT));
hal_nvic_enable_irq(GPIO_GET_IRQNUM(GPIO_KEY_PORT));
gpio_config.mode = GPIO_MODE_IT_RISING;
gpio_config.pull = GPIO_PULLDOWN;
walt
你好,我这边做了一个aon io6的测试,代码如下:
#define KEY_TEST_PIN  APP_IO_PIN_6
static volatile bool falling_edge_triggered_flag =false;
static volatile bool rising_edge_triggered_flag =false;
void app_gpiote_event_handler(app_gpiote_evt_t *p_evt)
if((APP_IO_TYPE_AON== (p_evt->type))&&(KEY_TEST_PIN ==(p_evt->pin)))
app_io_pin_state_t pin_level = app_io_read_pin(APP_IO_TYPE_AON,KEY_TEST_PIN);
if(pin_level)
rising_edge_triggered_flag =true;
else
falling_edge_triggered_flag =true;
const app_gpiote_param_t param[] =
{APP_IO_TYPE_AON, KEY_TEST_PIN, APP_IO_MODE_IT_FALLING, APP_IO_PULLUP, APP_IO_NONE_WAKEUP, app_gpiote_event_handler},
int main(void)
app_gpiote_param_t tmp_param;
/* Initial printf mode and UART */
app_log_assert_init();
printf("\r\n");
app_gpiote_init(param, sizeof (param) / sizeof (app_gpiote_param_t));
memcpy(&tmp_param,param,sizeof(app_gpiote_param_t));
while(1)
if(rising_edge_triggered_flag)
app_gpiote_deinit();
sys_delay_ms(10);
printf("rising_edge_triggered_flag:%d,falling_edge_triggered_flag:%d\r\n",rising_edge_triggered_flag,falling_edge_triggered_flag);
tmp_param.mode =APP_IO_MODE_IT_FALLING;
tmp_param.pull =APP_IO_PULLUP;
app_gpiote_init(&tmp_param,1);
if(falling_edge_triggered_flag)
sys_delay_ms(10);
tmp_param.mode =APP_IO_MODE_IT_RISING;
tmp_param.pull =APP_IO_PULLDOWN;
app_gpiote_init(&tmp_param, 1);
app_log_flush();
可以使用SK板 J40-1接线测试,个人觉得使用中断后开启timer延时,会比这种方法更通用一些
谢谢
