GR5526 内部PSARM使用 GR5526
185***524
2025-06-30 11:16
GR5526 中smart_watch 例程是使用的外部SPARM 怎么修改成内部PSARM
Seiyou
你好,请问smart_watch例程具体指哪一个呢?GR5526 SDK v1.0.3及之后版本所有的与图形相关的Example均使用的内部PSRAM
185***524
2025-06-30 13:16
uint16_t app_graphics_ospi_init(app_graphics_ospi_params_t * p_params)
app_graphics_ospi_config_t ospi_config;
uint8_t dev_id = 0x00;
if (NULL == p_params)
return APP_DRV_ERR_POINTER_NULL;
if(true != g_gpu_is_working) {
OSPI_DBG_PRINTF("Adjust DCore Policy Firstly (call app_graphics_adjust_dcore_policy())! \r\n");
ospi_adjust_dig_core_voltage();
ospi_power_on();
ospi_clock_on(p_params->ospi_freq);
ospi_set_io_mode(OSPI_IO_NOPULL);
ospi_config = s_ospi_config[(uint32_t)p_params->ospi_freq];
ospi_config.phy_delay_tap = p_params->phy_delay;
ospi_config.is_read_prefetch = p_params->is_read_prefetch;
ospi_config_init(&ospi_config);
app_graphics_ospi_reset();
delay_us(500);
ospi_set_reg_00h(p_params->rd_lc, p_params->drv_strength);
delay_us(100);
ospi_set_reg_04h(p_params->wr_lc);
delay_us(100);
dev_id = ospi_read_reg_02h() & 0x1F;
if(dev_id != OSPI_PSRAM_DEVICE_ID) {
OSPI_DBG_PRINTF("Invalid O.PSRAM ID: 0x%02x \r\n", dev_id);
return APP_DRV_ERR_INVALID_ID;
soc_register_nvic(OSPI_IRQn, (uint32_t)OSPI_IRQHandler);
ospi_set_access_mode(OSPI_ACCESS_MEMORY);
ospi_register_isr(ospi_interrupr_handler);
ll_ospi_x_set_dqs_timeout_interrupt(OSPI0, LL_OSPI_X_INTERRUPT_ENABLE);
NVIC_ClearPendingIRQ(OSPI_IRQn);
NVIC_EnableIRQ(OSPI_IRQn);
s_graphics_ospi_env.p_instance = OSPI0;
hal_pwr_mgmt_extra_device_suspend_register(EXTRA_DEVICE_NUM_OSPI, NULL, NULL);
hal_pwr_mgmt_extra_device_resume_register(EXTRA_DEVICE_NUM_OSPI, ospi_regs_resume, NULL);
memcpy((void*)&s_graphics_ospi_env.init_params, (void*)p_params, sizeof(app_graphics_ospi_params_t));
return APP_DRV_SUCCESS;
都是内部PSRAM吗
3条评论
