raw****com
Hello,
The goodix gt911 touch coordinates do not seem to generate touch events in the correct spot. Only the vertical coordinates are incorrect. The offset of x axis doesn't begin from 0. There is an offset of approximately 80 pixels knowing that the LCD resolution is 720x1280. we used this driver.
Any suggestions?
Goodix Admin
Hi,it is very sorry that this community does't provide Touch support,we suggest you contact the vendor of your device to get support. Thank you.
