651***269
The fingerprint scanner didn't work after upgrading to W11. After uninstalling the scanner + removing the drivers, the scanner was reinstalled with an older driver set (12/03/2020, 3/1/57.300) which solved the problem.
Working drivers:
Driver Name: oem6.infClass Guid: {53d29ef7-377c-4d14-864b-eb3a85769359}Driver Date: 03/12/2020Driver Version: 3.1.57.300Driver Provider: GoodixDriver Section: MyDevice_Install.NTDriver Rank: 0xFF0001Matching Device Id: USB\VID_27C6&PID_55A4Outranked Drivers: Device Updated: falseParent Device: USB\ROOT_HUB30\4&1083693b&0&0
Not working drivers:
Driver Name: oem145.infClass Guid: {53d29ef7-377c-4d14-864b-eb3a85769359}Driver Date: 03/11/2021Driver Version: 3.1.581.520Driver Provider: GoodixDriver Section: MyDevice_Install.NTDriver Rank: 0xFF0001Matching Device Id: USB\VID_27C6&PID_55A4Outranked Drivers: oem6.inf:USB\VID_27C6&PID_55A4:00FF0001Device Updated: trueParent Device: USB\ROOT_HUB30\4&1083693b&0&0
Hope this helps in solving this issue as once my system gets an automatic update I need to roll back to the older version to get the scanner working again
Goodix Admin
Hi, we are very sorry, but this community only supports Wireless Connectivity, Wearable Sensors. For fingerprint and touch product services, please contact your vendor. Thanks!
