Ask a New Question
Design Support
If you need one-on-one support for confidential technical issues with your project, please click on "Contact Us" below.
Current consumption gh3011
927***950
2023-08-17 03:28
Hello. In my gh3011 connection scheme, pins VDDIO and VCC are connected (voltage 2.8V). These pins have a constant current of 57 uA. Writing any ADT or HB configurations does not change the situation. There is always a leakage of 57 uA. Is there any way to solve this problem?
The datasheet states that in sleep mode, consumption is equal to 3 uA. How do I activate this mode?
0 Favorites
927***950
2023-08-24 22:09
In my schematic, the IIC_EN pin is connected to GND as I am using the SPI interface. If the IIC_EN pin is left floating, the current consumption becomes 3uA. If the IIC_EN pin is shorted to GND, the current between IIC_EN and GND will be 53 uA. How can I use the SPI interface and reduce power consumption?
0 Comments
0 Favorites
Your comment
927***950
2023-08-25 22:31
Partly, I was able to solve the problem of writing the value 0x0970 to register 0x000d. Power consumption drops to 3-4uA. Since there is no description of this register, I do not know why this happens. I discovered this accidentally.
0 Comments
0 Favorites
Your comment
You can answer questions after logging in, please or register
