Updated SVD File for GR551x
Resolved
die****com
2021-11-15 22:48
While checking the CMSIS pack "Goodix.GR551x.1.0.0.pack" for the GR551x family, I could spot multiple wrong details with the SVD file, for example SADC's base address appears as 0xA000E000, but FIFO_RD register addressOffset is 0x1B00, which means that the base address should be 0xA000C500 for relative referencing to work correctly, even though the real base address is indeed 0xA000E000. Also there are registers with wrong names like " DPAD_IN_EN" which according to the datasheet should be DPAD_RE_N, or DPAD_PULL_TYPE should be DPAD_RTYPE.
Also there are references in the Datasheet to GPIO 2 which appear nowhere else in the documentation nor the SVD file.
Is there any place where we can get an up to date version of the SVD file (and potentially the whole pack)? Thank you in advance
0 Favorites
The Best Answer
Goodix Employee
2021-11-16 14:00
Hi,
The "Goodix.GR5515x.1.0.0.pack" is an older version, it includes BLE and MCU part, it will cause compile errors.
We suggest that you don't need to download the CMSIS pack, we have configure it by default in our latest SDK version, the package is in the GR551x_SDK_V1.6.10\toolchain\cmsis\include directory.
You can download the latest SDK from the following address:
https://product.goodix.com/en/software_tool/gr551x_sdk#download
About how to use Keil to develop project, we have a document 《GR551x Developer Guide_Rev.2.3》, you can read the chapter 4 for details, you can download the latest 《GR551x Developer Guide_Rev.2.3》 from the following address:
https://product.goodix.com/en/docview/GR551x Developer Guide?objectId=79&objectType=document&version=165
If any problem, please tell us, Thanks.
Kellan.
Best Regards
0 Comments
1 Favorite
Your comment
die****com
2021-11-16 17:13
Thank you for your help Kellan, I was only missing some documentation on GPIO2's registers, but I presume they'll be just clones of 0 and 1 with no extra information necessary
0 Comments
0 Favorites
Your comment
