Ask a New Question
Get Supports
Driver GT911
Timo
2019-07-05 15:09
Hi Goodix-Team,
I want to kindly ask you, if there is a base driver for the GT911 (C-Code)?
At the moment I´m trying to implement the touch into the Renesas Synergy Platform.
And can you although send me the latest version of the Datasheet?
Thanks in advance!
Timo
0 Favorites
AndyIvan74
2019-07-06 06:31
Hi.
I am also trying to write the driver for the GT911 touchscreen controller for the RK043FN66HS-CTG by "Rocktech Displays". I also would like the c source code for this, please send to aihazelton@gmail.com
Can you please assist with how to configure and read the touch data?
I am communicating via I2C at 100 kbps and can send an receive data just fine. The programming manual and datasheet are quite vague as to how to set up the GT911. I need to use the GT911 in polling mode and only need to read one touch position at a time.
  • When I touch the screen with 1 finger I the Status Register [0x814E] will read 0x81.
  • When I touch the screen with 2 fingers I the Status Register [0x814E] will read 0x82.
  • When I touch the screen with 0 fingers I the Status Register [0x814E] will read 0x00, not touched.
This is good as it means that the GT911 is working correctly, please see the attached waveform images.
  1. But what do I need to write to the Real-time command (Write only) registers [0x8040 to 0x8100] for the RK043FN66HS-CTG?
  2. What mode is the GT911 supposed to be in (Receive mode, Slave Approach mode) ?
  3. Which registers do is read the touch point x and y coordinates from? The following registers just give the same values over and over, regardless of whether the screen is being touched or not.
0x8158 - Point 1 x coordinate (low byte)
0x8159 - Point 1 x coordinate (high byte)
0x815A - Point 1 y coordinate (low byte)
0x815B - Point 1 y coordinate (high byte)
0 Comments
0 Favorites
Your comment
AndyIvan74
2019-07-06 06:35
Also, I forgot to mention that I am developing a driver for embedded 'C' for an STM32F757 microcontroller on IAR workbench. Please send example code in 'C' on how to obtain a single finger touch co-ordinate in both polling mode and interrupt mode.
0 Comments
0 Favorites
Your comment
