weisen
GR551x_SDK_V2.0.1
下面的代码有问题,编译时总是出现报错,我将里面的内容屏蔽后就没有报错了
external\mbedtls\mbedtls-2.26.0_hw\include\mbedtls/ssl.h(463): error: #169: expected a declaration
union mbedtls_ssl_premaster_secret
#if 1
#if defined(MBEDTLS_KEY_EXCHANGE_RSA_ENABLED)
unsigned char _pms_rsa[48]; /* RFC 5246 8.1.1 */
#endif
#if defined(MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED)
unsigned char _pms_dhm[MBEDTLS_MPI_MAX_SIZE]; /* RFC 5246 8.1.2 */
#endif
#if defined(MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED) || \
defined(MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED) || \
defined(MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED) || \
defined(MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED)
unsigned char _pms_ecdh[MBEDTLS_ECP_MAX_BYTES]; /* RFC 4492 5.10 */
#endif
#if defined(MBEDTLS_KEY_EXCHANGE_PSK_ENABLED)
unsigned char _pms_psk[4 + 2 * MBEDTLS_PSK_MAX_LEN]; /* RFC 4279 2 */
#endif
#if defined(MBEDTLS_KEY_EXCHANGE_DHE_PSK_ENABLED)
unsigned char _pms_dhe_psk[4 + MBEDTLS_MPI_MAX_SIZE
+ MBEDTLS_PSK_MAX_LEN]; /* RFC 4279 3 */
#endif
#if defined(MBEDTLS_KEY_EXCHANGE_RSA_PSK_ENABLED)
unsigned char _pms_rsa_psk[52 + MBEDTLS_PSK_MAX_LEN]; /* RFC 4279 4 */
#endif
#if defined(MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED)
unsigned char _pms_ecdhe_psk[4 + MBEDTLS_ECP_MAX_BYTES
+ MBEDTLS_PSK_MAX_LEN]; /* RFC 5489 2 */
#endif
#if defined(MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED)
unsigned char _pms_ecjpake[32]; /* Thread spec: SHA-256 output */
#endif
#endif /* 0 */
登录后可回答问题,请 登录 或 注册
