今天加班吗
你好,我有以下ADC采集的疑问需要解答
设计目标:采用ADC0、1实现差分采样,ADC4单通道采样,2Khz中断采集
设计难题:ADC0、1在无输入信号时,采样信号与ADC4一致,若单独进行ADC0、1或ADC4采样则正常
代码:
ADC接口宏定义
/*******ADC IO CONFIG-VOL***************************/
#define VOL_ADC_P_INPUT_PIN MSIO_PIN_0
#define VOL_ADC_P_INPUT_PIN_MUX APP_IO_MUX_7
#define VOL_ADC_N_INPUT_PIN MSIO_PIN_1
#define VOL_ADC_N_INPUT_PIN_MUX APP_IO_MUX_7
#define VOL_ADC_N_INPUT_SRC ADC_INPUT_SRC_IO1
#define VOL_ADC_P_INPUT_SRC ADC_INPUT_SRC_IO0
/*******ADC IO CONFIG-VOL-single***************************/
#define VOL_SINGLE_ADC_P_INPUT_PIN MSIO_PIN_4
#define VOL_SINGLE_ADC_P_INPUT_PIN_MUX APP_IO_MUX_7
#define VOL_SINGLE_ADC_N_INPUT_PIN MSIO_PIN_4
#define VOL_SINGLE_ADC_N_INPUT_PIN_MUX APP_IO_MUX_7
#define VOL_SINGLE_ADC_N_INPUT_SRC ADC_INPUT_SRC_IO4
#define VOL_SINGLE_ADC_P_INPUT_SRC ADC_INPUT_SRC_IO4
定时器中断
static void app_tim1_event_handler(app_tim_evt_t *p_evt)
if (*p_evt == APP_TIM_EVT_DONE)
if(g_tim1_cnt >adc_collect_num)
app_tim_stop(APP_TIM_ID_0);
app_tim_stop(APP_TIM_ID_1);
vol_control_set(false);
printf("vol_adc_data_single vol_adc_data \n");
for(int i=0;i<adc_collect_num/2;i++)
printf("%f %f \n",vol_adc_data_single[i],vol_adc_data[i]);
else
if(g_tim1_cnt%2)
vol_adc_data[g_tim1_cnt/2]=vol_adc_recovery();
else
vol_adc_data_single[g_tim1_cnt/2]=vol_adc_signal();
g_tim1_cnt++;
ADC初始化及采集
app_adc_params_t vol_adc_params = {
.pin_cfg = {
.channel_p = {
.type = APP_IO_TYPE_MSIO,
.mux = VOL_ADC_P_INPUT_PIN_MUX,
.pin = VOL_ADC_P_INPUT_PIN,
.channel_n = {
.mux = VOL_ADC_N_INPUT_PIN_MUX,
.pin = VOL_ADC_N_INPUT_PIN,
.dma_cfg = {
.dma_instance = DMA0,
.dma_channel = DMA_Channel1,
.init = {
.channel_p = VOL_ADC_P_INPUT_SRC,
.channel_n = VOL_ADC_N_INPUT_SRC,
.input_mode = ADC_INPUT_DIFFERENTIAL,//ADC_INPUT_SINGLE,
.ref_source = ADC_REF_SRC_BUF_INT,
.ref_value = ADC_REF_VALUE_1P6,
.clock = ADC_CLK_8M,
app_adc_params_t vol_adc_params_single = {
.pin_cfg = {
.channel_p = {
.mux = VOL_SINGLE_ADC_P_INPUT_PIN_MUX,
.pin = VOL_SINGLE_ADC_P_INPUT_PIN,
.channel_n = {
.mux = VOL_SINGLE_ADC_N_INPUT_PIN_MUX,
.pin = VOL_SINGLE_ADC_N_INPUT_PIN,
.dma_cfg = {
.dma_channel = DMA_Channel2,
.init = {
.channel_p = VOL_SINGLE_ADC_P_INPUT_SRC,
.channel_n = VOL_SINGLE_ADC_N_INPUT_SRC,
.input_mode = ADC_INPUT_SINGLE,
.ref_value = ADC_REF_VALUE_1P2,
/**********************************电压采集-信号*****************************************/
double vol_adc_signal(void)
covn_done = 0;// 重置转换完成标志位
uint16_t ret = APP_DRV_SUCCESS;//初始化返回函数0x0000
double voltage[TEST_CONV_LENGTH],vol = 0;//原始数据采集数组
app_adc_deinit();
ret = app_adc_init(&vol_adc_params_single, app_adc_evt_handler);//配置ADC-差分ADC
if (ret != APP_DRV_SUCCESS)
printf("\r\nADC initial failed! Please check the input parameters-vol_adc_signal.\r\n");
return 0;
app_adc_dma_deinit();
ret = app_adc_dma_init(&vol_adc_params_single);
printf("\r\nADC initial dma failed! Please check the input parameters-vol_adc_signal.\r\n");
return 0;
memset(conversion, 0, sizeof(conversion)); // 将conversion数组的内存全部清零
app_adc_conversion_async(conversion, TEST_CONV_LENGTH);
// app_adc_dma_conversion_async(conversion, TEST_CONV_LENGTH);// 启动异步ADC转换(使用DMA)
while(covn_done == 0);// 等待转换完成(covn_done会在转换完成后被置位)
adc_close();
app_adc_voltage_intern(conversion, voltage, TEST_CONV_LENGTH);// 将原始ADC值转换为电压值
for(uint32_t i = 0; i < TEST_CONV_LENGTH; i++)// 累加所有采样值
vol += voltage[i];
return vol/TEST_CONV_LENGTH;// 返回平均值
/**********************************电压采集-回采*****************************************/
extern volatile int g_tim1_cnt;
double vol_adc_recovery(void)
covn_done = 0;
double voltage[TEST_CONV_LENGTH],vol_single = 0;//原始数据采集数组
app_adc_deinit();
ret = app_adc_init(&vol_adc_params, app_adc_evt_handler);//配置ADC-差分ADC
printf("\r\nADC initial failed! Please check the input parameters-vol_adc_recovery.\r\n");
return 0;
ret = app_adc_dma_init(&vol_adc_params);
printf("\r\nADC initial dma failed! Please check the input parameters-vol_adc_recovery.\r\n");
return 0;
adc_close();
vol_single += voltage[i];
vol_adc_recovery_data[g_tim1_cnt][i] = voltage[i];
return vol_single/TEST_CONV_LENGTH;
返回数据为
登录后可回答问题,请 登录 或 注册
