Ping
Long Range是BLE 5.0 新增加的特性,能够增加蓝牙的通信距离,将最大的发送功率,从4.0/4.1/4.2中的10mW增大到5.0的100mW,如下图所示:
注意:Long Range的广播与普通BLE广播不兼容,所以广播、扫描双方必须都设置为Long Range。
1. GR551X 支持Long range模式,硬件相关规格如下:
2. SDK中设置方法如下: 调用ble_gap_phy_update接口切换PHY,选择BLE_GAP_PHY_LE_CODED参数即可,接口调用和参数说明可以参考throughput工程和<GR55xx_BLE_Throughput示例手册_V1.9.pdf>文档介绍。
/**@defgroup BLE_GAP_PHYS GAP PHYs (bitmask) * @{ */#define BLE_GAP_PHY_ANY 0x00 /**< No preferred PHY. */#define BLE_GAP_PHY_LE_1MBPS (1 << 0) /**< LE 1M PHY preferred for an active link. */#define BLE_GAP_PHY_LE_2MBPS (1 << 1) /**< LE 2M PHY preferred for an active link. */#define BLE_GAP_PHY_LE_CODED (1 << 2) /**< LE Coded PHY preferred for an active link. *//**@} *//** **************************************************************************************** * @brief Set the PHY preferences for the connection identified by the connection index. * @note Once this operation has been completed, the callback function @ref gap_cb_fun_t::app_gap_phy_update_cb will be called. * * @param[in] conn_idx: The index of connection. * @param[in] tx_phys: The transmitter PHYs that the Host prefers the Controller to use (see @ref BLE_GAP_PHYS). * @param[in] rx_phys: A bit field that indicates the receiver PHYs that the Host prefers the Controller to use (see @ref BLE_GAP_PHYS). * @param[in] phy_opt: A bit field that allows the Host to specify options for PHYs (see @ref BLE_GAP_PHY_OPTIONS). * * @retval ::SDK_SUCCESS: Operation is Success. * @retval ::SDK_ERR_INVALID_CONN_IDX: Invalid connection index supplied. * @retval ::SDK_ERR_NO_RESOURCES: Not enough resources. **************************************************************************************** */uint16_t ble_gap_phy_update(uint8_t conn_idx, uint8_t tx_phys , uint8_t rx_phys, uint8_t phy_opt);(1) tx_phys和rx_phys都要设置为Coded PHY;
(2) phy_opt设置为1是500kbps,设置为2是125kbps,设置为0表示不指定;
3. 关于设置1M PHY & Long range广播共存的方法如下:
基于projects\ble\ble_basic_example\ble_app_gap_extended_adv例程
(1). 重构extended_adv_start函数,增加广播通道和PHY设置参数;
static void extended_adv_start(uint8_t adv_idx, \ gap_le_phy_value_t prim_pyh, \ gap_le_phy_value_t second_pyh, \ const uint8_t *adv_data){ sdk_err_t error_code; ble_gap_pair_enable(false); s_gap_adv_param.type = GAP_ADV_TYPE_EXTENDED; s_gap_adv_param.disc_mode = GAP_DISC_MODE_GEN_DISCOVERABLE; /* The advertisement shall not be both connectable and scannable, and High duty cycle directed advertising cannot be used */ s_gap_adv_param.prop = GAP_ADV_PROP_CONNECTABLE_BIT; s_gap_adv_param.max_tx_pwr = 0; s_gap_adv_param.filter_pol = GAP_ADV_ALLOW_SCAN_ANY_CON_ANY; memset(&s_gap_adv_param.peer_addr, 0, sizeof(gap_bdaddr_t)); s_gap_adv_param.prim_cfg.adv_intv_min = APP_ADV_MIN_INTERVAL; s_gap_adv_param.prim_cfg.adv_intv_max = APP_ADV_MAX_INTERVAL; s_gap_adv_param.prim_cfg.chnl_map = GAP_ADV_CHANNEL_37_38_39; s_gap_adv_param.prim_cfg.phy = prim_pyh; s_gap_adv_param.second_cfg.max_skip = 0; s_gap_adv_param.second_cfg.phy = second_pyh; s_gap_adv_param.second_cfg.adv_sid = 0x00; s_gap_adv_param.period_cfg.adv_intv_min = 0; s_gap_adv_param.period_cfg.adv_intv_max = 0; error_code = ble_gap_ext_adv_param_set(adv_idx, BLE_GAP_OWN_ADDR_STATIC, &s_gap_adv_param); APP_ERROR_CHECK(error_code); error_code = ble_gap_adv_data_set(adv_idx, BLE_GAP_ADV_DATA_TYPE_DATA, adv_data, (adv_data[0]+1)); APP_ERROR_CHECK(error_code); s_gap_adv_time_param.duration = 0; s_gap_adv_time_param.max_adv_evt = 0; error_code = ble_gap_adv_start(adv_idx, &s_gap_adv_time_param); APP_ERROR_CHECK(error_code);}(2) 开启1M PHY & Long range广播
static const uint8_t s_adv_data_set_coded_pyh[] ={ 0x0e, BLE_GAP_AD_TYPE_COMPLETE_NAME, 'L', 'o', 'n', 'g', 'R', 'a', 'n', 'g', 'e', '_', 'A', 'D', 'V',};static const uint8_t s_adv_data_set_1M_pyh[] ={ 0x0d, BLE_GAP_AD_TYPE_COMPLETE_NAME, 'E', 'x', 't', 'e', 'n', 'd', 'e', 'd', '_', 'A', 'D', 'V',};/* * GLOBAL FUNCTION DEFINITIONS ***************************************************************************************** */void disconnect_task(void){ sdk_err_t error_code; error_code = ble_gap_adv_start(0, &s_gap_adv_time_param); APP_ERROR_CHECK(error_code); error_code = ble_gap_adv_start(1, &s_gap_adv_time_param); APP_ERROR_CHECK(error_code);}void ble_init_cmp_callback(void){ sdk_err_t error_code; gap_bdaddr_t bd_addr; sdk_version_t version; sys_sdk_verison_get(&version); APP_LOG_INFO("Goodix GR551x SDK V%d.%d.d (commit %x)", version.major, version.minor, version.build, version.commit_id); error_code = ble_gap_addr_get(&bd_addr); APP_ERROR_CHECK(error_code); APP_LOG_INFO("Local Board X:X:X:X:X:X.", bd_addr.gap_addr.addr[5], bd_addr.gap_addr.addr[4], bd_addr.gap_addr.addr[3], bd_addr.gap_addr.addr[2], bd_addr.gap_addr.addr[1], bd_addr.gap_addr.addr[0]); //Long Range extended_adv_start(0, GAP_PHY_CODED_VALUE, GAP_PHY_CODED_VALUE, s_adv_data_set_coded_pyh);//1M PHY extended_adv_start(1, GAP_PHY_1MBPS_VALUE, GAP_PHY_1MBPS_VALUE, s_adv_data_set_1M_pyh);}
131***607
5515有沟通群吗?有些问题请教一下
