今天加班吗
采用GR551x.SDK-v2.1.0\projects\peripheral\pwm\app_pwm\Keil_5例程,无法动态修改占空比,通道B代码输出为10Khz,50%占空比方波,用GR551x_SDK_V1.7.0例程可动态修改占空比,请问原因是在哪里
#define APP_PWM0_MODULE APP_PWM_ID_1//APP_PWM_ID_0
#define APP_PWM0_GPIO_MUX APP_IO_MUX_5
#define APP_PWM0_CHANNEL_A APP_IO_PIN_7//APP_IO_PIN_2
#define APP_PWM0_CHANNEL_B APP_IO_PIN_8//APP_IO_PIN_3
#define APP_PWM0_CHANNEL_C APP_IO_PIN_9//APP_IO_PIN_4
#define APP_PWM0_GPIO_TYPE APP_IO_TYPE_NORMAL
app_pwm_params_t pwm_params = {
.id = APP_PWM0_MODULE,
.pin_cfg = {
.channel_a = {
.type = APP_PWM0_GPIO_TYPE,
.mux = APP_PWM0_GPIO_MUX,
.pin = APP_PWM0_CHANNEL_A,
.pull = APP_IO_NOPULL,
.enable = APP_PWM_PIN_ENABLE,
.channel_b = {
.pin = APP_PWM0_CHANNEL_B,
.channel_c = {
.pin = APP_PWM0_CHANNEL_C,
.active_channel = APP_PWM_ACTIVE_CHANNEL_ALL,
.init = {
.mode = PWM_MODE_FLICKER,
.align = PWM_ALIGNED_EDGE,
.freq = 10000,
.bperiod = 500,
.hperiod = 200,
.channel_a = {
.duty = 30,
.drive_polarity = PWM_DRIVEPOLARITY_POSITIVE,
.channel_b = {
.duty = 50,
.drive_polarity = PWM_DRIVEPOLARITY_NEGATIVE,
.channel_c = {
.duty = 80,
void app_pwm_test(void)
uint16_t ret = APP_DRV_SUCCESS;
app_pwm_channel_init_t channel_cfg = {0};
ret = app_pwm_init(&pwm_params);
if (ret != APP_DRV_SUCCESS)
printf("\r\nPWM initial failed! Please check the input paraments.\r\n");
app_pwm_start(APP_PWM0_MODULE);
while(1)
channel_cfg.duty = 20;
channel_cfg.drive_polarity = PWM_DRIVEPOLARITY_POSITIVE;
app_pwm_config_channel(APP_PWM0_MODULE, APP_PWM_ACTIVE_CHANNEL_ALL, &channel_cfg);
delay_ms(2000);
channel_cfg.duty = 80;
delay_ms(2000);
// delay_ms(2000);
// app_pwm_update_freq(APP_PWM0_MODULE, 1000);
// channel_cfg.duty = 20;
// channel_cfg.drive_polarity = PWM_DRIVEPOLARITY_POSITIVE;
//#if (APP_DRIVER_CHIP_TYPE != APP_DRIVER_GR551X)
// channel_cfg.fstoplvl = PWM_STOP_LVL_LOW;
//#endif
// app_pwm_config_channel(APP_PWM0_MODULE, APP_PWM_ACTIVE_CHANNEL_B, &channel_cfg);
// app_pwm_inactive_channel(APP_PWM0_MODULE, APP_PWM_ACTIVE_CHANNEL_A);
//#endif
// delay_ms(2000);
// app_pwm_stop(APP_PWM0_MODULE);
// delay_ms(2000);
// channel_cfg.duty = 60;
// channel_cfg.fstoplvl = PWM_STOP_LVL_HIGH;
//#endif
// app_pwm_config_channel(APP_PWM0_MODULE, APP_PWM_ACTIVE_CHANNEL_ALL, &channel_cfg);
// app_pwm_start(APP_PWM0_MODULE);
// delay_ms(2000);
// app_pwm_deinit(APP_PWM0_MODULE);
int main(void)
board_init();
printf("\r\n");
printf("***********************************************************\r\n");
printf("* PWM_Output example. *\r\n");
printf("* *\r\n");
printf("* PWM_a(MSIOA*) *\r\n");
printf("* PWM_b(MSIOA*) *\r\n");
printf("* PWM_c(MSIOA*) *\r\n");
printf("* *\r\n");
printf("* This sample code will show PWM output. *\r\n");
printf("* You can use logic analyzer to get PWM_a/b/c wave *\r\n");
printf("* on MSIOA*/MSIOA*/MSIOA* *\r\n");
app_pwm_test();
#if (APP_DRIVER_CHIP_TYPE == APP_DRIVER_GR5332X)
app_pwm_coding();
app_pwm_coding_dma();
#endif
printf("\r\nThis example demo end.\r\n");
while(1);
登录后可回答问题,请 登录 或 注册
