gr5526 模拟器编译问题 GR5526
260****com
2024-04-25 15:31
编译5526的lvgl模拟器 链接时提示如下错误,我使用MSYS 下mingw64 环境
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libm.a when searching for -lm
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libm.a when searching for -lm
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lm: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libkernel32.a when searching for -lkernel32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libkernel32.a when searching for -lkernel32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lkernel32: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libuser32.a when searching for -luser32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libuser32.a when searching for -luser32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -luser32: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libgdi32.a when searching for -lgdi32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libgdi32.a when searching for -lgdi32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lgdi32: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libwinspool.a when searching for -lwinspool
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libwinspool.a when searching for -lwinspool
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lwinspool: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libshell32.a when searching for -lshell32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libshell32.a when searching for -lshell32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lshell32: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libole32.a when searching for -lole32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libole32.a when searching for -lole32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lole32: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../liboleaut32.a when searching for -loleaut32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\liboleaut32.a when searching for -loleaut32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -loleaut32: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libuuid.a when searching for -luuid
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libuuid.a when searching for -luuid
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -luuid: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libcomdlg32.a when searching for -lcomdlg32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libcomdlg32.a when searching for -lcomdlg32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lcomdlg32: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libadvapi32.a when searching for -ladvapi32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libadvapi32.a when searching for -ladvapi32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -ladvapi32: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libmingw32.a when searching for -lmingw32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libmingw32.a when searching for -lmingw32
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lmingw32: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/libgcc.a when searching for -lgcc
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0\libgcc.a when searching for -lgcc
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lgcc: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/libgcc_eh.a when searching for -lgcc_eh
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0\libgcc_eh.a when searching for -lgcc_eh
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lgcc_eh: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libmoldname.a when searching for -lmoldname
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libmoldname.a when searching for -lmoldname
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lmoldname: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libmingwex.a when searching for -lmingwex
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libmingwex.a when searching for -lmingwex
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lmingwex: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libmsvcrt.a when searching for -lmsvcrt
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libmsvcrt.a when searching for -lmsvcrt
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lmsvcrt: No such file or directory
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libpthread.dll.a when searching for -lpthread
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../libpthread.a when searching for -lpthread
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: skipping incompatible D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../..\libpthread.a when searching for -lpthread
D:/soft/msys2/msys2/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lpthread: No such file or directory
collect2.exe: error: ld returned 1 exit status
mingw32-make[2]: *** [CMakeFiles\GR5526LVGLSimulator.dir\build.make:2921: GR5526LVGLSimulator.exe] Error 1
mingw32-make[1]: *** [CMakeFiles\Makefile2:82: CMakeFiles/GR5526LVGLSimulator.dir/all] Error 2
mingw32-make: *** [Makefile:90: all] Error 2
wyang0126@wyang MINGW64 /f/code/company/gr5526/GR5526_SDK_V1.0.2/projects/peripheral/graphics/graphics_lvgl_831_gpu_demo/simulator/build
Seiyou
您好,较新版本的MinGW-w64移除了32-bit的标准库,所以会导致链接不过。请尝试使用一个旧版本的带multilib的MinGW-W64(例如 https://sourceforge.net/projects/mingw-w64/files/Multilib%20Toolchains%28Targetting%20Win32%20and%20Win64%29/ray_linn/gcc-10.x-with-ada/ )或直接使用MinGW32进行编译。
可以通过gcc -v的输出中是否包含--enable-multilib确认编译器是否含有32-bit的标准库。
3条评论
