rit****com
Hi Team ,
We are part of Wipro BQTF and we are looking for a reference sample for Bluetooth Direction finding (AoA/AoD) radio testing in conducted mode.
Can you suggest any sample supported for AoA/AoD which can be performed in Conducted mode radio testing.
Regards,
Rithesh.
Hi, the GR5526 supports the AoA/Aod feature, you can have a look at the SDK and the doc in the attachment first.
rit****com
can this board used for conducted mode Radio testing where antennas are connected directly to tester using rf cables?
1. Yes, it supports using the RF cables.
2. Regarding the AoA/AoD, we just support reporting the IQ data, we don't provide the API to calculate the angle through the IQ data.
rit****com
Hi team.
Our tester has 4 antenna cables coming out for texting AOA/AOD, whether this board supports to connect these four antenna cables.
Hi,
1. Our chip supports 4 antennas, but the SK board doesn't support 4 antennas.
2. You can design a new board, then use the GPIO to select the antenna.
