eag****com
I used the Sleep mode and WDT in GR5515 for battery saving and fault management.
WDT_Refresh function resets watchdog timer counter value. I called this function in main while loop.
But if MCU enter in deep sleep mode, main while loop is not called, I think.
So, the MCU is reset automatically.
Could you let me know the solution?
Thanks.
Hi, you can use app timer to refresh the watchdog before watchdoh is expired.
