Ask a New Question
Design Support
MSIO interrupt with GR551X GR551x
623***567
2022-12-30 17:26
Hi Goodix,
We use the Goodix GR5515IGND and one of the interrupts is connected to the MSIO_PIN_3. In the SDK, I can see that there are no functions for handling interrupts on pins of the MSIO type through the app_gpiote functions.
Can you please tell me how to handle interrupts through the SDK for MSIO type pins?
0 Favorites
Goodix Employee
2022-12-30 19:03
1. Hi, MSIO doesn't support interrupt.
2. If you want generate interrupt in sleep mode (chip is in sleep mode), you need to use the AON_GPIO.
3. If you want generate interrupt in active mode (chip is in active state), you can use AON_GPIO and normal GPIO(GPIO_0 to GPIO_31)
0 Comments
0 Favorites
Your comment
