Ask a New Question
Design Support
GT911 firmware/cfg config data needed
qpang
2019-06-19 23:24
Hi, I am using this LCD module CT050HDFIA020-C020A with Android. (ordered from: https://www.alibaba.com/product-detail/5-0-IPS-720x1280-MIPI-LCD_60692134930.html)
Can you provide the firmware/ cfg config data for GT911? I have the driver code but in one of the files it says "ask vendor to provide cfg data". My email address is qpang190@gmail.com. Thank you!
0 Favorites
Raymond
2019-06-30 19:20
hi,qpang,the cfg data is different due to different sensor design。There was the cfg data in IC Flash,you can read it through driver。Now is driver accessed?
0 Comments
0 Favorites
Your comment
