Ask a New Question
Design Support
GR5526 Starter Kit with PSD 360×360 LCD – Screen not turning on, BLE works
991***009
2026-03-06 15:13
Hello Goodix Support Team,
I am using the GR5526 Starter Kit (GR5526-SK-BASIC-REV.E) along with the PSD 360×360 v2 LCD (20240229).
I have the following issue:
  • The BLE functionality works correctly, both with your Gprogrammer/testing tool and using the examples provided in your SDK folder.
  • The LCD screen does not turn on. I have tried several methods and examples, but the screen remains off.
  • Specifically, the graphics example provided in the SDK folder does not work on the LCD, even though BLE examples work fine.
Things I have tried:
  1. Verified that the LCD clip is properly attached to the board.
  2. Tested BLE example code – works fine.
  3. Tried the LCD graphics example provided in the SDK – the screen does not turn on.
  4. Reset the board and power-cycled multiple times.
Could you please guide me on why the LCD graphics example is not working and how to get the LCD screen working properly?
Thank you very much!
0 Favorites
Seiyou
Goodix Employee
2026-03-09 16:37
Hi,
Which GR5526 SDK do you use? Please try GR5526 SDK V1.0.3 Patch 1 from https://github.com/goodix-ble/GR5526.SDK/releases or GR5526 SDK v1.0.4 from Goodix official site. The correct example project for this screen module is projects\peripheral\graphics\graphics_lvgl_831_gpu_demo_360p
0 Comments
0 Favorites
Your comment
