Ask a New Question
Design Support
what is the right way to use RG_BIA_SLOT_TIME_LENGTH GH3300
par****com
2025-01-28 21:12
Hi!
We use GH3300 to measure impedances in slot mode. Does the RG_BIA_SLOT_TIME_LENGTH item determine the duration of one slot when measuring impedance? How can I convert the value of this item into time units?
What does the RG_BIA_T3_SET item mean?
0 Favorites
Tim
Goodix Employee
2025-02-06 12:03
RG_BIA_SLOT_TIME_LENGTH, every slot time,the value map is follow:
0: 4/62.5Hz
1: 8/62.5Hz
2: 16/62.5Hz
3: 32/62.5Hz
4: 64/62.5Hz
5: 96/62.5Hz
6: 128/62.5Hz
7: 192/62.5Hz
8: 256/62.5Hz
Run time for each frame includes slot run time and QC time (default: 160ms)
0 Comments
0 Favorites
Your comment
