j.w****com
Hi,
I'm a Linux kernel engineer. As a side project I've lately been working on improving support for Intel Bay Trail, Cherry Trail and Apollo Lake based devices. Many of these devices contain a Goodix GT9xx touchscreen controller.
In most cases the Goodix touchscreen-controller just works with the Linux driver for GT9xx controllers. But on some devices with a GT912 controller the Linux driver needs to upload the firmware for the controller to the controller. I've recently added support to Linux for uploading the firmware:
https://lore.kernel.org/linux-input/f0ac9d1d-8869-b0ae-8b04-7a2c92d0e203@redhat.com/T/#t
In order to allow Arch Linux, Fedora, Ubuntu or Steam OS to work out of the box on devices with a GT912 which needs the firmware to be uploaded, without users needing to manually find and install the firmware file I would like to add these files to the linux-firmware repository where the Linux community collects firmware files for various devices:
https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/
All files in this repo need to have a specific license attached to them, I would like to use the MIT license for this, which is a very simple license simply stating that distributing these files is allowed:
https://mit-license.org/
Can I have your permission to add the firmware files which need to be uploaded to the GT912 controller on some devices to the linux-firmware repository under the MIT license? To be clear I'm talking about the 32768 bytes / 4 sections of the "main" firmware which needs to be uploaded to SRAM bank 0 + 1 as well as about the 4096 bytes of DSP firmware which needs to be uploaded to SRAM bank 2 and also the 228 bytes of config data.
Regards,
Hans
Goodix Admin
Hi,it is very sorry that this community does't provide Touch support,we suggest you contact the vendor of your device to get support. Thank you.
