Same as the title, can anyone share the PWM module function in MCU?
PMW is a square wave signal, also known as a pulse.
Pulse width modulation, engineering control pulse waveform.
Pulse Width Modulation,control the analog circuitry with the digital output of the microprocessor.
PWM refers to the waveform, which is a square wave, which is generally used to
control the motor.
Hot Latest
