Ask a New Question
Design Support
Goodix Touch Driver Issue.
tdk****com
2019-12-03 22:07
Nice to meet you.
I bought a tablet PC called Teclast X6 Pro.
This product uses a Goodix touch driver.
Currently, touch operations are working without problems.
However, there is a problem with the operation of the pen and I want to ask a question.
Looking at the specs, this tablet can recognize 1024 levels of pen pressure.
Using a software that can check the pen pressure value,
if you slowly apply power, the pen pressure value will reach from 0 to 1024, and if you apply more force, the value will be zero.
Even in this state, the position of the pen tip is recognized according to the pen (the pressure value is 0, so no line is drawn).
Isn't the touch driver misrecognizing that this panel or pen is at 2048 level?
I want the driver to be modified to work with pen pressure values from 0 to 1024.
best regards.
Teclast X6 Pro / Windows10
HID Driver : GoodixTouchDriver Device Ver.4.4.2.4128
Pen Driver : HID standard pen Ver.10.0.18362.175(Microsoft)
0 Favorites
Goodix Admin
Community Administrator
2019-12-09 17:58
Hi, please contact Teclast for technical support, Our FAE will help solve this problem.
0 Comments
0 Favorites
Your comment
