Ask a New Question
Design Support
How to use AON WDT of GR5515 GR551x
Resolved
eag****com
2024-10-30 22:24
I am going to use AON WDT when system fails.
I have integrated WDT to my code. It works but I couldn't control wdt callback(event handler, alarm callback). It seems not working.
SDK: GR551x_SDK_V2.0.2, My test code is as follows.
0 Favorites
The Best Answer
Goodix Employee
2024-11-01 19:49
Hi ,
1. Could you replace the ble_app_template example main.c with below code and do som tests?
#include "user_app.h"
#include "user_periph_setup.h"
#include "gr_includes.h"
#include "scatter_common.h"
#include "flash_scatter_config.h"
#include "custom_config.h"
#include "patch.h"
#include "app_log.h"
#include "app_aon_wdt.h"
 * LOCAL VARIABLE DEFINITIONS
/**@brief Stack global variables for Bluetooth protocol stack. */
STACK_HEAP_INIT(heaps_table);
app_aon_wdt_params_t s_aon_wdt_params = {
    .init = {
        .counter = 0x00FF,
        .alarm_counter = 0x1a,
    .aon_aon_wdt_env = NULL,
void app_aon_wdt_evt_handler(void)
    printf("A\r\n");
int main(void)
    // Initialize user peripherals.
    app_periph_init();
    // Initialize ble stack.
    ble_stack_init(ble_evt_handler, &heaps_table);
    // Initialize won wdt.
    app_aon_wdt_init(&s_aon_wdt_params , app_aon_wdt_evt_handler);
    // loop
    while (1)
        app_log_flush();
        pwr_mgmt_schedule();
        sys_delay_ms(500);
        app_aon_wdt_refresh();
2 Comments
1 Favorite
Your comment
eag****com
2024-11-01 20:36
Thanks for your help!
It works well. I noticed that wdt_event_handler is timed out in short time.
I printed text "event handler called\r\n" but before print finished, system reset so some of print text is displayed in app logo.
If I should call NVDS_PUT in event handler, I wonder if this function is exactly run.
2 Comments
0 Favorites
Your comment
