561***493
Is it possible to obtain drivers for a Goodix Touchscreen controller that is used in a mini 2 in 1 laptop. Contact with the manufacturer has not worked. The touchscreen in not working at the present time and I believe it is a driver issue. The hardware ID is as follows: acpi\ven_gdix&dev_1001. I have done extensive research trying to enable the touchscreen. It worked originally but a Win 10 reset wiped out all drivers. I've been able to recover all but the touchscreen. The brand is Peakago and the motherboard is Eii. I'm hoping to get some help from Goodix support. Thank you.
Don DeLucia
ddelu7408@comcast.net USA
Goodix Admin
Hi Don, so sorry to tell you that this community does't provide touchscreen support, here is the Goodix touch drivers link on github, you can take a look for reference, hope it works.
Link:
https://github.com/goodix
