858***587
I am trying to integrate the goodix_gt6853 driver to NXP imx kernel (5.4). I am following the steps given in the porting guild in the doc directory. Can you please share the porting and guide? Also, Is there a Buildroot package folder which can be used to port it on Buildroot build system?
I adding the driver following doc in the github page. It is still giving me the "Not able to load .bin and .cfg". Not sure how to find and add these files.
https://github.com/goodix/gtx8_driver_linux
[GTP-INF][goodix_i2c_init:1933] Goodix driver init
[GTP-INF][goodix_fwu_module_init:1588] goodix_fwupdate_module_ini IN
[GTP-INF][goodix_register_ext_module:161] goodix_register_ext_module IN
[GTP-INF][goodix_register_ext_module:166] goodix_register_ext_module OUT
[GTP-INF][goodix_gsx_gesture_init:418] gesture module init
[GTP-INF][goodix_i2c_probe:1810] goodix_i2c_probe IN
[GTP-INF][goodix_parse_dt:152] get reset-gpio[135] from dt
[GTP-INF][goodix_parse_dt:160] get irq-gpio[137] from dt
[GTP-INF][goodix_parse_dt:235] ***key:0, 0, 0, 0
[GTP-INF][goodix_ts_core_init:2084] Core layer init
[GTP-INF][goodix_ts_probe:1959] goodix_ts_probe IN
[GTP-INF][goodix_ts_power_init:1141] Power init
[GTP-INF][goodix_ts_power_init:1156] Avdd name is NULL[skip]
[GTP-INF][goodix_ts_power_on:1172] Device power on
[GTP-INF][goodix_ts_pinctrl_init:1240] Failed to get pinctrl handler[need confirm]
[GTP-INF][goodix_ts_gpio_setup:1291] GPIO setup,reset-gpio:135, irq-gpio:137
[GTP-INF][goodix_ts_probe:2031] goodix_ts_probe OUT, r:0
[GTP-INF][goodix_i2c_probe:1869] i2c probe out
[GTP-INF][__do_register_ext_module:137] Module [goodix-fwu] registered,priority:1
[GTP-INF][goodix_read_cfg_bin:423] cfg_bin_name:goodix_cfg_group.bin
gtx8 0-005d: Direct firmware load for goodix_cfg_group.bin failed with error -2
gtx8 0-005d: Falling back to sysfs fallback for: goodix_cfg_group.bin
[GTP-ERR][goodix_read_cfg_bin:428] failed get cfg bin
[goodix_cfg_group.bin] error:-11, try_times:1gtx8 0-005d: Direct firmware load for goodix_cfg_group.bin failed with error -2gtx8 0-005d: Falling back to sysfs fallback for: goodix_cfg_group.bin
[goodix_cfg_group.bin] error:-11, try_times:2
[GTP-ERR][goodix_read_cfg_bin:438] get cfg_bin FAILED
[GTP-ERR][goodix_cfg_bin_proc:167] Failed get valid config bin data
[GTP-INF][goodix_generic_noti_callback:1872] notify event type 0x7
[GTP-INF][goodix_cfg_bin_proc:211] cfg bin state 1, ret -11
[GTP-ERR][goodix_later_init_thread:511] parse cfg bin encounter error, -11
[GTP-ERR][goodix_later_init_thread:516] parse cfg bin encounter fatal err
[GTP-INF][goodix_ts_core_release:2101] goodix core module removed
[GTP-INF][goodix_ts_power_off:1206] Device power offDebugfs module exit
Goodix Admin
Hi,it is very sorry that this community does't provide Touch support,we suggest you contact the vendor of your device to get support. Thank you.
