291****com
我在国民技术的开发板上移植GH3026模块的库,主控是国民的N32G452,选择的通讯方式是SPI,在调用汇顶提供的SDK v4300里面提供的demo,Gh3x2xDemoInit()函数-》GH3X2X_Init()函数里面尝试唤醒芯片时总是失败,读取寄存器0x0036里面的内容是0xf100,却不是0xaa55,请问这个是什么原因呢??
国民的sip初始化如下:
void hal_gh3x2x_spi_init(void)
/* init spi and cs pin */
SPI_InitType SPI_InitStructure;
GPIO_InitType GPIO_InitStructure;
/*!< GPIO Periph clock enable */
RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA | RCC_APB2_PERIPH_GPIOB, ENABLE);
/*!< SPI1 Periph clock enable */
RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_SPI1, ENABLE);
/**SPI1 GPIO Configuration
PA5 ------> SPI1_SCK
PA6 ------> SPI1_MISO
PA7 ------> SPI1_MOSI
PB0 ------> SPI1_CS
/*!< Configure SPI1 pins: SCK */
GPIO_InitStructure.Pin = GPIO_PIN_5;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitPeripheral(GPIOA, &GPIO_InitStructure);
/*!< Configure SPI1 pins: MOSI */
GPIO_InitStructure.Pin = GPIO_PIN_7;
/*!< Configure SPI1 pins: MISO */
GPIO_InitStructure.Pin = GPIO_PIN_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/*!< Configure SPI1 pin: max86140 CS pin */
GPIO_InitStructure.Pin = GPIO_PIN_0;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitPeripheral(GPIOB, &GPIO_InitStructure);
/* Configure the SPI1 pin: SPI_INT */
GPIO_InitStructure.Pin = GPIO_PIN_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; // 浮空输入模式
/*!< SPI configuration */
SPI_InitStructure.DataDirection = SPI_DIR_DOUBLELINE_FULLDUPLEX;
SPI_InitStructure.SpiMode = SPI_MODE_MASTER;
SPI_InitStructure.DataLen = SPI_DATA_SIZE_8BITS;
SPI_InitStructure.CLKPOL = SPI_CLKPOL_HIGH;
SPI_InitStructure.CLKPHA = SPI_CLKPHA_SECOND_EDGE;
SPI_InitStructure.NSS = SPI_NSS_SOFT;
SPI_InitStructure.BaudRatePres = SPI_BR_PRESCALER_16;
SPI_InitStructure.FirstBit = SPI_FB_MSB;
SPI_InitStructure.CRCPoly = 10;
SPI_Init(SPI1, &SPI_InitStructure);
/*!< Enable the SPI1 */
SPI_Enable(SPI1, ENABLE);
GU8 hal_gh3x2x_spi_write(GU8 write_buffer[], GU16 length)
GU8 ret = 1;
ret = SPI1_ReadWriteByte(write_buffer[0]);
return ret;
GU8 SPI_SendByte(GU8 byte)
/*!< Loop while DAT register in not emplty */
while (SPI_I2S_GetStatus(SPI1, SPI_I2S_TE_FLAG) == RESET)
/*!< Send byte through the SPI1 peripheral */
SPI_I2S_TransmitData(SPI1, byte);
/*!< Wait to receive a byte */
while (SPI_I2S_GetStatus(SPI1, SPI_I2S_RNE_FLAG) == RESET)
/*!< Return the byte read from the SPI bus */
return SPI_I2S_ReceiveData(SPI1);
// SPI1 读写一个字节
// TxData:要写入的字节
//返回值:读取到的字节
GU8 SPI1_ReadWriteByte(GU8 TxData)
GU8 Rxdata;
Rxdata = SPI_SendByte(TxData);
return Rxdata; //返回收到的数据
登录后可回答问题,请 登录 或 注册
