152***479
硬件:手表 + GH3020。
ODR配置:100Hz HRV + 25Hz HR + 25Hz Acc 。
SDK版本与配置:
Gh3x2xDemoInit : Democode Version : GH(M)3X2X_DEMO_v1.5_AC_v0.4(build:Nov 18 2024_14:47:45)
Gh3x2xDemoInit : DrvLib Version : v4.1.0.0 (build:Nov 1 2022_09:44:25)
Gh3x2xDemoInit : Config Version : Gh3x2x_Virtual_Reg_v3.4
[gh3x2x_algo]: version = GX_HARDADT_SOFTCHECK_v0.1
Gh3x2xDemoInit : Algo Version : GX_HARDADT_SOFTCHECK_v0.1
[gh3x2x_algo]: version = GX_HBA_2.2.0.0(Delta)_S_CONF_nc_goodix_dsp_v1.0.3.2
Gh3x2xDemoInit : Algo Version : GX_HBA_2.2.0.0(Delta)_S_CONF_nc_goodix_dsp_v1.0.3.2
[gh3x2x_algo]: version = HRV_v_2.4.0a
Gh3x2xDemoInit : Algo Version : HRV_v_2.4.0a
[Gh3x2xDemoStartSampling] unFuncMode = 0x7
[Gh3x2xSampleRateUpdate]FunctionId = 0x1, slot bit = 0x40,usSampleRateUser = 5
[Gh3x2xSampleRateUpdate]FunctionId = 0x2, slot bit = 0x2,usSampleRateUser = 25
[Gh3x2xSampleRateUpdate]FunctionId = 0x4, slot bit = 0x1,usSampleRateUser = 100
[Gh3x2xSampleRateUpdate]Down sample: FunctionID = 0x1,: SlowestSlotSR = 5, Factor = 0
[Gh3x2xSampleRateUpdate]Down sample: FunctionID = 0x2,: SlowestSlotSR = 25, Factor = 0
[Gh3x2xSampleRateUpdate]Down sample: FunctionID = 0x4,: SlowestSlotSR = 100, Factor = 0
Current uchSlotEn= 0x43
Current g_unDemoFuncMode= 0x7
[Non-Sync Gsensor]usRefFucntion = 0x4.
[Non-Sync Gsensor]g_fGh3x2xNonSyncGsensorStep = 1.000.
[Non-Sync Gsensor]usRefFucntion = 0x4,usSampleRateMax = 100.
[Non-Sync Gsensor]non-sync gsensor init.
[gh3x2x_algo]: [goodix_hba_init_func]:params = 0,0,25,4,0,0,0,
[gh3x2x_algo]: [goodix_hrv_init_func]:params = 0,320000,160000,30000,30000,
我们是运动算法的提供商(CyweeMotion),想利用该心率模块的 HRV 功能做睡眠评估。我们测试这款心率的HRV时,有以下疑问需要向贵司咨询:
1. 我们算法将正常PPI值范围定义为:[60000/(HR+10) ~ 60000/(HR-10)] 。这种定义是否合理?如果不合理,您认为是合理的范围或者方式是什么?
2. 测试者心率范围: 90~103bpm 。在静息状态下测试HRV时,有时候会出现有3个PPI值的情况(概率较低,但60000/PPI≈心率),大部分交替出现 1-2个PPI值。这种现象是否正常?
3. 使用 [60000 / PPI ≈ 心率值] 评估当前PPI值的可靠性是否合理?如果不合理,有什么好方法?
4. 100HZ HRV的ppg信号的频谱能量分布是否集中在心率值附近?这样我们可以判断当前 HRV ppg 信号质量。
PS:
佩戴时,已经要求测试者将手表紧贴手腕且表带有一定的弹性。
wan****com
回复如下:
1、心率计算是平均值,HRV的波段会是比较大的,HR的波动差异不止±10。由于人群差异较大,不好确定建议范围。
2、测试者的心率范围是如何获取的?是否是其他设备测试心率。3个PPI值可能是信号比较差的情况,结合1的情况,也可能是某个时间段差异导致。
3、结合1的情况,不建议这么定义PPI值可靠性,可以参考汇顶算法输出的置信度,用于衡量当前信号质量。
4、方法是可以这么判断,但是需要心率对齐金标心率值(如心率带)。
