写技术文章
MCUBoot and TF-M Introduce
李孝超
2022-05-27 11:20:41
1. Secure Boot Solution
1.1. MCUBoot
• User: Zephyr/Mynewt/RIOT/MBED-OS/…;
• Driver port: Flash/Uart/Usb/OTA/Crypto/Platforms init;
• Crypto module supported: MbedTLS/TinyCrypt;
• Update type
• MCUBOOT_OVERWRITE_ONLY: secondary->primary;
• MCUBOOT_SWAP_USING_MOVE: primary->swap, secondary->primary;
• Hook function:
• boot_read_image_header_hook: check image header;
• boot_image_check_hook: image check,e.g. image index, slot number
• boot_perform_update_hook: perform a clean image update;
• boot_read_swap_state_primary_slot_hook: boot swap state item check;
• boot_copy_region_post_hook: netcore update after appcore update
• boot_serial_uploaded_hook: netcore update in serial console;
1.2. MCUBoot Flow
2. TEE Solution
2.1. Trusted Firmware-M(TF-M)
TF-M is the reference implementation of PSA. (like op-TEE used for Cortex-A), it support a set of secure run time services.
• Secure Storage
• tfm_platform_mem_read
• Cryptography:
• hashing with SHA-256
• generating random numbers
• Audit Logs
• Attestation
2.12. TF-M -> Support Platform
• ARM: Corstone-1000/Corstone-300/Corstone-Polaris/Musca-B1
• NXP: LPCXpresso55S69
• Cypress
• STM
• Nordic: nrf5340/nrf9160
• Laird Connectivity: BL5340
• Nuvoton: M2351/M2354
2.13. TF-M -> Architecture
