909***952
Hello Goodix team,
We are developing product based on GH3011. We want to use the full possibilities of this. Unfortunatelly, the lack of information in documentation doesnt give to us this (example described only 14 registers from 70). May I ask you to share documentation with the more detailed descriptions for:
registers;
the library and source code;
Thanks in advance.
che****com
Hi,As for the GH3011 product development requirements you mentioned, you can contact our agent to obtain them. Please refer to the following link. Thank you
https://www.goodix.com/zh/support/distributors
909***952
Hello,
We initially contacted to the distributer and got feedback: "We don't have the document which explains 70 or more registers . In fact,we want these too ,but it's protected by Goodix. Goodix only release some APIs and example code." (c)
Development without registers is quite difficult and spend so many times.
che****com
Hi,As for the description of registers, we will release a new version of EVK tool, which will integrate the usage instructions of relevant registers into the tool. It is expected to be updated to you next week, thank you
909***952
Hello, Have it been released new EVK? Is possible to get it?
che****com
Hi,The attachment is the corresponding new version of EVK tool, please check。After decompressing, please double-click the corresponding EXE file。Click Generator on the home page and click Create Config->Universal in turn. Select HB, SPO2, HRV and ADT Confirm on the Apps interface. In the Hardware Parameter on the right, select the Green, IR and Red switches of the switch button. Then click the Generate button in the lower right corner. Next you will see the common register description, including address, function, and set values and corresponding instructions。
thanks
