505***892
Hi,
I use touchscreen controlled by Goodix GT911. I have connected touch screen to my x86 Apollo Lake Intel board(sca, scl, ground and vcc. Interrupt -> pull_up, reset to system reset). I have checked if there is a goodix driver in linux kernel and there is. After I have entered "modprobe goodix" command in Ubuntu and I have added goodix module to /etc/modules as well but It does not work. I have tried out different physical connection but the result has not changed. What can I do to run it properly?
Thanks,
Goodix Administrator
Hi,it is very sorry that this community does't provide the touch support,we suggest you contact the vendor of your device to get support. Thank you.
